Please Support JNZ Tuning
Coolant overflow keeps overfilling and coolant level goes down. Why?
96gstdsm
808
2
Aug 7, 2006
monroe, New_York
My car has just finished getting many mods, one including a fmic that has been giving me some cooling problems. I have been overheating. The highest I have seen was 224 that was on the hottest day of the year. The temps only get really hot when I am on the highway and only sometimes with the stock needle go up to almost 3/4 to hot. I had a logger hooked up before to monitor the temps but don't have it hooked up at the moment.
I checked my coolant levels and they were a little low, so I added some water and coolant. My overflow was right at the correct level.
After driving for some time and then checking it again the next day, I looked and my overflow tank was overfilled and my coolant levels in the radiator and all went down.
I am not burning any coolant or anything and have no smoke or anything coming out.
Why does my coolant keep going from my radiator and lines to my overflow tank?
Could a bad radiator cap cause this? I have a new one I am putting on as soon as it cools down.
Would just overheating in general cause this?
Also why would my car only sometimes overheat when on the highway going the same speed and with the temperatures outside being the same. When driving around they will go up and down when traveling at the same speeds. And sometimes during my trip the needle will stay right around the middle line if not below and other times it will be 3/4 to hot.
The needle acted the same when I was able to monitor the temps as well.
I seem to have a similar problem, every now and then it appears that my coolant level has dropped. My car stays completely perfect temp around town but once im on the freeway the temps start to rise and rise and rise?
Could be a bad rad cap but this is also a classic sign of a blown headgasket, pressure getting into the system and pushing out the coolant into the overflow. Check to see if the coolant is milky or also if there is any coolant in your oil
I had the same problem.. Turns out I had a leak in my cooling system by my overflow tank. I replaced the tank and it never happened again. I would start narrowing down where you could have a possible leak and start from there.
-new rad cap
-new thermostat
-purge system of air bubbles, squeeze lower rad hose 10-15 times with engine running and heater on high (rad cap off, bubbles should come to top)
-top up to brim under cap with 50/50 mix or so
-fill resevior to low mark on cold engine
double check upper rad hose gets warm (thermostat open)
double check fan is on
double check water pump is spinning
coolant should stay within the high, and low line or maybe theres other issues then consult the wisemen
Sounds like a headgasket to me, My truck did the same thing to me. every few days I would dump the overslow back in the the rad. I finiley checked the thte system with a block tester and OPPS blown hg
check your hose in your overflow tank from the cap. i've seen where the hose doesn't go down like it should, sometimes it folds up if your not careful. that would let coolant drain into the overflow and not get sucked back into the cooling system. hope that helps
had the same problem with my 1g was a headgasket the kid that had the car before me put a diffrent head on the car but didnt have it resurfaced so i ended up with a nice head gasket leak
OK well got a new radiator cap and it seems to have fixed the overflow tank filling up to high. My coolant temp gauge(stock) also has not gone over half way really with the ac fan on always since I put the new cap on. I don't have the ecu+ engine management hooked up right now to confirm that the temps have gone down for sure or not though. Will shortly.
I recently had my car compression and boost leak tested by a good friend and everything checked out ok. My compression was 135 across the board and the only leak we could find boost wise was at my throttle body cause my shaft seals are bad. So i ordered new shaft seals and got a new isc. I also replaced my thermostat not even a year ago with a oem unit. I also wired my ac fan to my regular fan so both fans come on when one does. but now my coolant keeps over filling my catch tank and over flowing...a lot. It only over flows out of the catch tank. It seems as if i add coolant everyday. Any clues as to what could be causing this? I don't have any leaks in my system either. Any help or ideas would be greatly appreciated.
having the same problem, but when I boost I get a whiff of coolant...not sure if it is coming out of my overflow and hitting my exhaust (becuase my overflow has been moved to be on my firewall) or if my motor is burning it due to a hg blowout. going to put a new rad cap on today and see what it does...if no fix, im gonna do a coolant pressure test and see WTF is up....I will post up results later this evening.:thumb:
