View Single Post
Old 09-06-2007, 07:30 AM   #11 (permalink)
JayRolla
Proven Member
JayRolla's Avatar
Region: Rocky Mountain
Classifieds Rating: (6)
Reputation: JayRolla is extremely helpful and trustworthyJayRolla is extremely helpful and trustworthy
Sorry, Ive been busy so have not been able to reply. You need about 33% more fuel flow to run e85. 1000cc injectors on e85 would run out at about 400-500whp. I would say at least 850cc's for a 16g.
All he changed was the fuel line from the filter to the rail. Cars build from 89 and up usually have a different type of rubber in the lines and the e85 wont corrode it. Only issue would be the 1g metal tank but we have had people running it for over a year with no problems.
Also a wbo2 is mandatory. Sometimes the e85 is more like e90 or e70. This will cause your afr to change so its nice to have a wbo2 so you dont run lean and burn a valve.
We would have started at about 26psi but he started getting a misfire. We are going to lower the spark plug gap to about .022-.024 and turn the boost up. Then start adding timing.
The fuel is incredible. People are making more power with e85 than c16 race gas. My mechanic said it will never detonate. He can add so much timing it starts to become to much and actually robs power. Its just incredible stuff.
We are hoping to break 400whp but with stock cams and a 2.5inch exhaust I dont see it happening.
Offline
Sponsored Links
