my check engine light comes up as idle control fault
seamus7
66
Jun 29, 2007
InFrontOfU, New York
my check engine light comes up as idle control fault...... what can i do to make it go away....
i did change the throttle body from a 2nd gen to a 1st gen, but the electrical on the trottle body is all from the 2nd gen.... what else can i do?... to only reason i changed it was because we did a pressure test and the 2nd gen trottle body leaked and i had a 1st gen sitting around, then when i put it on it surged... so i took it off and replaced the electrical on the bottom of the throttle body with the 2nd gen electrical.... can you guys help? what should i do? so now i have a 1st gen throttle body with 1st gen electrical components on it!WTF :dsm:
