Please Support Rix Racing
How to Remove Washer Nozzles?
Bobster66
46
Dec 5, 2004
Toronto, ON_Canada
I'm painting my hood and want to remove the nozzles for the window washers. Are there any tricks to getting them off?
They should just pop out if not there will be a screw on the bottom of the hood, but usually you can just pull on them after you disconnect the hoses. You may even be able to press up on the nipple from the bottom side of the hood to push out the nozzle.
Take a pair of pliers and twist them 90* and pull up. Don't expect to reuse them after.
