Sick of your MSD boxes failing? Dynatek has a proven track record in other markets and have now come out with plug and play CDI boxes for the 95-99 DSMs and the 2003-2004 Evo VIII!
We are the East Coast distributor for DSM and EVO Dynatek CDIs.
• Smallest Lightest CDI on the market
• Simplified Plug in harnesses for easy installs without need for tach adapters
• Over 189mJ delivered to the coil per spark, the highest of any on the market
• Over 500V to the coil primary
• Over 50kV to the coil secondary (assuming a 100:1 coil)
• Intelligent Spark Profiling (ISP) allows for less delay between successive sparks
• Spark Restrike up to 4500 RPM
• Provides this high level of output from as low as 8 Volts from the battery
• Works with any 2 coil OEM ignition, with or without factory ignitor (some systems may require replacement coils)
• Built in launch limiter, works from 2000-11900 RPM
• Built in fixed timing retard function
• Tach output
Technical specifications:
Operating Voltage: 8-20 Volts
Operating Current: 7.0A @ 10,000 RPM
Maximum Operational RPM: 18,000 + RPM
Ignition Inputs: 2 rising or falling edge
Ignition Outputs: 2 independent channels
Coil Primary Energy Max: 189+ mJ
Coil Primary Voltage Max: 500+ V
Restrike Window: 25 crankshaft degrees
Launch limiter input: Single wire, ground to activate launch limit.
Retard input: Single wire, ground to activate timing retard
Tach output: 12V square wave, 50% duty cycle
Dimensions: 4" x 4.6" x 1.4"
Weight: < 1.25 lb.
RETAIL PRICE- $399.99
SALE PRICE- $359.99!!!
Order online at
http://jnztuning.net/proddetail.php?prod=DYNA_ARC-2a or give us a call at the shop.
215-997-6850
