dsm-onster
DSM Wiseman
- 8,592
- 130
- Jul 11, 2004
Bloxom,
Virginia
Well, the MHI 14b 16g turbos seam to do fine w/ a head fed oil line. So these turbos don't seam to need the astronomical oil pressures that other journal bearing turbos love.
Considering many have plumbed from the filter housing and have had no ill effects, I thought that I'd try it. Cleaner, cooler oil. Has anyone added a turbo feed line filter to a 14b/16g/18g/20g? I have one lying around from my 60-1 turbonetics. I have a braided stainless line from the housing and the adapters to connect it to my small 16g. Am I being overly cautious? or is it a good idea? Has a oil filter lowered the oil pressure too much for some? I've never used a feed from the filter housing for a MHI unit. . .
and blew through the turbo filter and blew through the metal head line. The filter seams to be little more restrictive. But I am doubting the oil pressure would be cut in half from the flow restriction, right? And if so this is the operating rainge from MHI units fed from the head, anyway. Just trying to fix something here that's not broke
. Besides, I lost my turbo side banjo bolt for the feed line the other day
