View Single Post
Old 08-02-2007, 05:23 PM   #100 (permalink)
Blitzeclips
Proven Member
Blitzeclips's Avatar
Region: Tri State
Classifieds Rating: (2)
Reputation: Blitzeclips is pretty helpful and trustworthy
Heh. OK. I know what a quality piece is. Trust me.
But no one has even tested this manifold enough for ANYONE, I meen ANYONE on here to say it's a piece of shit. Right now, every single one of you whom say that are stating an OPINION. It doesn't fit, big deal. Make it fit. The general purpose for buying this part is to increase performance, not buying something that must, HAVE TO, NEED to fit perfectly. If it increases performance, who cares if you need to make it fit?
Until someone puts it on to flow chart, heat cycles and material tests, no one will know. Period. It could be the best flowing manifold in the world for all we know.
All I'm saying is, none of us know for sure. If you need to improvise then so be it, you'll still see the same performance then before you modified it.
Seems like everyone knocked it from the get-go because you needed to trim a piece from the T-stat housing and dismissed any potential it may have had you put some elbow grease into it and making it fit and actually testing the manifold for true results.
Offline
[posts] Reply With Quote
Sponsored Links
