View Single Post
Old 07-27-2007, 10:43 AM   #6 (permalink)
silverbullett
Proven Member
silverbullett's Avatar
Region: NorCal
Classifieds Rating: (0)
Reputation: silverbullett is more helpful than not
Quote:
Originally Posted by Locke View Post
Copper core plugs will work much better with our ignition system than platinum plugs. NGK BKR6E-11 or BKR6ES-11 are the preferred plugs for stock engines. Try using BKR7E-11/BKR7ES-11 with nitrous, and read your plugs every once and a while. If you find them fouling, go back to the 6's, if they are getting hot, step up to 8's. Driving habits will decide which heat range you need. (BTW NGK coppers are well under $2 each.)
Read here for short discussion on transmission oil coolers. Transmission Cooler
Listen to this guy, he knows what he's talking about.
Online
Sponsored Links
