View Single Post
Old 07-21-2007, 09:29 AM   #21 (permalink)
VelocitąPaola
DSM N/T Moderator
VelocitąPaola's Avatar
Region: Southeast
Classifieds Rating: (5)
Here we go again...
The 420A MAP sensor only reads from full vacuum to 0psi boost. It can't read anything beyond that because we use missing links/FCDs to prevent fuel cut (which happens when the stock ECU reads 1psi or more of boost). Since the S-AFCII alters the MAP signal, it's only really modifying a small portion of the entire vacuum/boost range. Once the car enters boost, any settings you've programmed into the S-AFC become null as a different device (FMU, S-FMU, etc.) are now taking control.
The stock 450s would work well, but we'd need a resistor pack, and a S-FMU to control them.
____________________________
-Paul
Online
Sponsored Links
