View Single Post
Old 07-09-2007, 10:37 AM   #252 (permalink)
Blitzeclips
Proven Member
Blitzeclips's Avatar
Region: Tri State
Classifieds Rating: (2)
Reputation: Blitzeclips is pretty helpful and trustworthy
I am still confused about the whole co2 thing. I'm hesitant to even take a stab at it actually. From what it sounds like, the wastegate will be independant to the manifold charge because that manifold charge can be replaced by the co2. Rather then waiting for the gate to open or close, he can control it by charging it with co2. So the wastegate stays closed under high boost, and only opens on command. Same thing with low boost except he can add the charge for an earlier boost response.
Either that or he's creating some sort of vaccuum to pull the pressure into the wastegate quicker, so it thinks theres more pressure then there is?
I don't know.
Is this co2 going to be controlled manually or set via module/program supported in the boost controller/logger?
Offline
[posts] Reply With Quote
