I have another block in works right now....but will not finish it unit we find the limits of this block, if it holds good then nothing will change with that part.
I got Drive Shaft Shop axles stage 5 pn the way.
The trannie was fully re-built with new everything.
Twin disc clutch
drilled and taped 4 more bolt holes throw the flex plate and flywheel so 8 oem bolts attach the flexplate the the flywheel now.
Quafie LSD
thats about it for the tranny i hope i hold up.....i guess will find out.... if it blows i might just order a Darrell cox racing automatic tranny
____________________________
RAM
