View Single Post
Old 06-26-2007, 09:28 AM   #9 (permalink)
linksys42
Proven Member
Car: 90 Corolla
Region: Midwest
Classifieds Rating: (2)
Reputation: linksys42 is an unknown
I am having a prob with my recently acquired Recirculated forge. I have tried the green spring and the yellow spring, the green spring wasn’t holding boost in 1st gear it would leak boost then all of a sudden hold and shoot up to 14psi so I thru the yellow one in and it stopped but they both made the same sound when releasing between shifts and at low boost/partial throttle release. But I keep on getting this psssshhwhinng it sounds like a 1g bov releasing with a high pitched ring and it doesn’t seem to shift as smoothly, unless I run full boost at every shift then it releases quick? Also at low boost partial throttle it makes a low pitched ring? It this normal or is it compressor surge? Thanks
Offline
Sponsored Links
