Set your tune as best you can for the higher boost settings. I have a fwd as well as an awd and I use a simple two stage MBC for the fwd. I run stock boost 1-2 gears and hit the switch so its full boost for third gear. You probably lose a little power on the tune for the lower boost but thats why you run the two stage boost controller so that you can lose some power to get some traction in the lower gears. I just run a simple two stage mbc from dejon btw.
