- 2,699
- 118
- Sep 4, 2004
Eau Claire,
Michigan
Well today, I was going to go to TRE and have Jon check out my trans.
I leave and head down the road and pull up to a stop sign and the car all of a sudden idles at about 2500 RPM. I'm like OK??? I get out and try adjusting the Biss, maybe it came loose? But no, it was nearly closed. I couldn't see anyting physically wrong but I took it back home anyways.
Back home, I found that the "throttle closed switch" on the TB, the wire had broken off. I thought, great, easy fix, this has to be the problem. Fixed the wire, didn't help. Still super high, and steady (no surging) idle.
So I start to think, maybe the ISC somehow broke or stuck open? I know the ISC was bad b/c I've had idle surging problems for a while. But anyways, I get out the multimeter and check the resistance in the coils in the ISC. Coil check 5-6 failed. It didn't read anything at all. I thought, great I just have a bad ISC that finally took a big shit. I grapped an extra ISC laying around, checked it with the multimeter and it was good. Installed it, Still high steady idle at 2500 or so RPM.
Now I'm lost. DSMLink Idle is set at 1000. Not throwing any codes for TPS, ISC, etc. I've verified base timing at 5*. I've also checked and re-adjusted the throttle cable.
The trottle body has just been rebuilt by my buddy Jim. Its a 1g TB, with the FIAV still functioning.
Is there any way the FIAV is stuck or broken or torn or something? I'm lost right now on why it started this and hasn't stopped. Even after the car sitting for 5 hrs, it still did it.
Any ideas and advice are greatly appreciated.
Thanks, Dan.
Thanks, Dan.
scary as hell. If one of those screws were to back out bye bye engine.
