empie1
- 1,063
- 5
- Dec 30, 2004
albany,
New York
I finally got my logger took a couple runs..Im idleing at like 950 and at idle the timing reads 14...However, as I accelerate, the timing acts strange.
3rd gear
rpm timing
2912 23 degrees
3028 26 degrees
3160 22 degrees
3296 5 degrees
3500 4 degrees
4184 7 degrees
4496 8 degrees
4692 8 degrees
Mind you the boost is only set at 8psi.I have never done anything with a logger so I dont even know what to be looking for.Is this normal?If not, what is the timing supposed to look like and how do I make it like that?
thanks
mike
3rd gear
rpm timing
2912 23 degrees
3028 26 degrees
3160 22 degrees
3296 5 degrees
3500 4 degrees
4184 7 degrees
4496 8 degrees
4692 8 degrees
thanks
mike
