dsmclipse97
- 214
- Aug 20, 2006
Merrimack,
New Hampshire
hey guys, I just ordered the treadstone turbo kit which can be seen here:
https://redhat3.admarkonline.com/~treadstone/product.phtml?p=235&cat_key=12&prodname=420a+Turbo+kit+95-99+Eclipse+Talon
I know the kit isnt perfect, the downpipe needs to be welded and the IC piping looks universal but you cant beat that price and im very ready to get my hands dirty. I know i will also need the fuel components. I am planning on a 255lph walbro for the fuel pump. But i have questions on the rest of the fuel system. What ratio should i get for a rising rate FMU? a 12:1? and which FMU works the best with our cars? also, do i need a FCD? I a little scared of overboost as i plan on running 8psi and i know our engines wont take much over 10. The kit also comes with the option of a garret T3 turbo for like $100 less. i know nothing about these and am wondering if anyone has any thoughts on them or the tubonetics t3/t4 that the kit comes with. As a final question should i get larger fuel injectors? possibly 270cc or 310cc and if i do do i need any sort of engine management or is the FMU good enough.
sorry about the long post but i need to start ordering the rest of the parts ASAP. thanks in advance for any advice.
...cause they suck. You can also, if you would like to, take your oil pan off now and weld a bung or whatever you're going to use and put a cap on it. And, you can put your fuel pump in, boost gauge, pillar mount, and i dont know about the FCD or not, I just waited on that. And, if you feel to let out that little bit of ricer in you, you can install the IC with no piping...just a thought.
