nightspeed87
- 1,761
- 12
- May 2, 2006
Tampa,
Florida
Bere with me here. To being I just Finished my 6bolt build motor swap two months ago, and have about 1300miles on the new engine in the car. I am using the stock tranny/ clutch.
Well the past two week ive been hearing this chattering sound when i pressed down the clutch pedal ( even if I only pressed it in a little bit )
It would go away whenever the clutch wasnt being pressed. Well i replaced my master and slave clinders due to some shifting/ fluid leaking problems and adjusted the pedal correctly.
Shifted fine after that point but the chattering when the clutch was pressed didnt go away.
Last night was driving my car and took off hard in first ( but not launching it )
I hear a nasty sound and immediately let off and then it wouldnt let me put it back in gear and I ended up having to push the car out the road and get it towed.
As I was waiting for the tow truck it didnt want to crank in gear and only in neutral and when I tried to push the clutch down it immediately began making a nasty harsh squeeling sound coming from the tranny and the engine was trying to cut off like it was binding up somewhere.
A friend told me sparks came from under the car ( open flywheel cover )
I had a friends dad who works at a tranny shop listen to the sound today and he thinks its either from a throw out bearing that went out, or a bad/ or improperly installed pressure plate . Any ideas, i hope this didnt harm my engine/ tranny/ or new fidanza light weight 9lb flywheel...?
Before I have the tranny teared down i want to get an idea of what you guys may think the culprit is and what after effects or anything because if it was an install problem i need to be able to point fingers at the engine installers and have a strong defense on the situation. Thanks
