mhuffman
- 292
- 4
- Nov 3, 2006
Bowie,
Maryland
Is there a better way to clean fuel injectors than to just run fuel system cleaner thru the system? I've already run a good cleaner thru and the problem hasn't gone away.
I am getting a bad misfire above 4k rpm's at full boost, perfect driveability when i'm not WOT. I recently put in NGK plugs and Accel wires so those shouldn't be the problem. I've also done a pressure test and i dont have major leaks. I'm not throwing a CEL, and i get good (25+) gas mileage. 91 FWD turbo... The car spins tires in second gear so its not like its low on power. But it drives terrible at WOT high rpm ever since i did my 2.5" cat and 3" DP.
I'm thinking it's either my ignition coil or one or more of my fuel injectors. Any ideas?
, guess you didn't get to try the whole injector testing instructions that everyone was talking about.
