VPrime
- 802
- 3
- Feb 5, 2006
Lonon,
ON, Canada
As the title says I need some help relocating my deck in my 2G..
The double din slots in my car are now a molded in 7" monitor..
I need to move the deck some where else because I still need it.
I want it in the similar area as I dont feel like extending/rewiring
I had some ideas.
-One was to cut a square hole right below the DIN slots.. where the cigarette lighter is.I could slide the Deck in through there, then put one of those plastic trim pieces that come with head units around it to cover up..
Problems with this idea is.. its very expensive to undo (would need to replace the that whole part of the dash) If i ever decide to go with a different set up.
Also the fact that I think thats where the ECU is..
-another idea was to put the deck in the Center vent.
Problem with this one is, it looks really out of place, I want the whole set up to look almost OEM. Also I wouldn't know what to do with he vents, would I need to some how close off the vent? and how would I support the whole head unit.. I cant really get in there to put a brace, so it would basically be held in place by the small plastic trim.
-Third idea was to stick it in the glove box. I don't REALLY need access to the deck, but it would be nice to have. Problem here is IF i need to use the deck, I am sort of in a situation where I cant reach.. 99% of the time I will be fine with out it though...
-4th idea was an extension to the third.. put the whole thing int he deck, but put the face plate in the driver side sun visor.
Problem is that i would have to do pass wires through the car.. Not a fan of this
Also the fact that soldering wires tot eh small connections on the faceplate and head unit would be a PAIN..
Oh the whole purpose of this is for my computer set up. I am having a computer handle All of the audio etc. But need the deck to power the speakers (don't want to rewire, or buy another amp).
I think my 3rd option is the best.. But I dont know... help me decide, or give new ideas.
Thanks.
I had some ideas.
Thanks.
