Splitpi
- 1,204
- 28
- Sep 13, 2005
Des Moines,
Iowa
As the title says, I am trying to put together for my records a fairly complete list of parts for a 2G 7-bolt rebuild that will yeild a near new and reliable engine that is good to ~ 350 crank HP. Let me know any changes, oppinions or corrections.
Description (Qty) (Total Price)
Stock 7-bolt Crank (1) ($0)
Stock 7-bolt Rods (4) ($0)
Stock 2g Pistons 8.5:1 (4) ($0)
4G63T Mitsu Full Gasket Set 95-99 (1) ($74)
4G63T Brass Freeze Plugs (9) ($9)
4G63T Accessory Belt Package (1) ($32.90)
4G63T Timing Kit Pkg 4 96-99 (includes waterpump, pulleys, tensioners and belts) (1) ($217)
4G63 Balance Shaft Eliminator Kit (1) ($49)
4G63T Piston Rings set 95-99 (1) ($57.25)
SI Bronze Valve Guide Set (1) ($100)
4G63 3rd Gen Lifters (1) ($80)
Valve Locks (16) ($35.04)
4G63 Oil Pump Assembly (1) ($164)
DOHC Sprocket Locking Tool by Lisle 36880 (1) ($34.05)
"Standard Blues" Valve Seals.. 16pc (1) ($25)
Brian Crower Springs & Retainer Kit (1) ($219.07)
Mitsu ARP 94-99 11mm Head Studs (1) ($92)
ARP Main Studs 90-99 (1) ($63)
ARP 7bolt Rod Bolts (1) ($44.95)
Clevite Main Bearing Set (1) ($59.99)
Clevite Rod Bearing Set (1) ($40.01)
Sum total: $1,396.26 in parts ... estimate $600 in machine work for decking/honing and polishing the rods/crank/block.
