Aside from the cams (which I suspect you could resell on Neons.org for about $250+), you should be able to use the rest of that stuff. Be sure to find out if those pistons are twenty over or whatnot so you can have your blockbored accordingly. I suspect the manifold will boltup, but I can't promise anything. Your IC piping will definitely need reworking, but for $500, it's a hell of a deal. Go for it.
____________________________
DR1665.com | GVR4 rally
