boostedzxtt
- Dec 31, 2006
Ardmore,
Oklahoma
Recently I replaced a Valve Cover Gasket on a 91 TSI AWD, because it was leaking oil. Then I found out the valve cover was cracked and that was causing the leak. This is the least of my worries right now though. After installing the gasket I drove the car around the block and it ran without problems, so I thought I'd just look for a valve cover.... untill I started it up today. The car is idling horibbly and it seemed to be coming from the valve train, but it is so loud that I can't even narrow it down to a certain area. Plus if you hold your hand over the muffler you can litteratly feel it sucking in, instead of blowing the exhaust out. Keep in mind that the car was running fine the day before. Anyone have any idea what this could be? Also I will check the codes later today or tomorrow.
