Clutch Going
turbogsx16
How would test to see if your clutch is going?? I'am having to take my car to like 3 1/2 rpms for the turbo to engage. Any suggestions would help!! Thank You.
R.
3 and 1/2 thousand RPM's for the Turbo to engage? Do you mean clutch. And u shouldnt have to rev the gas to get teh clutch to engage, since thats actually worse for. Explain a little further so we can help u more.
Here's how it is. clutch engages fine I'm just needing to go to 3 1/2 rpms to see boost. Mods are 16G turbo, FMIC, SAFC, 660 injectors, Greddy BOV type S, 2G MAF, Greddy Profec B. I have boost set at 17psi. Thank You!
It won't be the clutch then because you just said it engages fine, and if it were the clutch you would get boost but no go.
