General 2g first log Palmnstein
appleyard777
98
33
Jun 15, 2005
Cleveland, Tennessee
ok i dont know how the hell do get it on my computer? i followed the instructions fully on palmnstein. i have no idea how to get the file i save on my pc!
any help would be appreciated but this is what i can gather by replaying it and pausing it by frames.
This is a 3rd gear with an evo 3 16g, FP2 cams, fmic, full exhaust, SAFC II -10 across the board on 22psi (pump gas)
Rpms, o2v, timing
3rd gear
4289, 0.93, 5
4699, 0.93, 5
5082, 0.93, 6
5511, 0.93, 9
6000, 0.93, 11
Do you have the logger link software installed and running on your computer?
That timing looks low, but at least it's climbing.
Shouldn't the correction factor be more for 550's?
well the logs don't have enough data. when i use pl viewer to look at my logs i just use the function prnt screen button, copy it into paint and then host it on here...you need to go from 2500-redline...i'm guessing you dont have a wideband?
also, i'm very curious, because i have the same setup as you and i'm -40 across the board on 20psi, with a good afr, but in no fashion should you tune your car to those numbers!!! i'm not responsible LOL...get a better log and repost!
Sorry, my experience is limited to 1G stuff with MMCD. Only advice I can really give you is to make sure all the latest or most appropriate software is installed. Some palm software is only compatable with specific operating systems on your palm. Reinstall things if necessary.
-40!! damn well ive only got 550's, and a 190lph with fp2 cams, evo 3 16g, fmic, turbo back, etc etc, at 22psi. That seems helllla lean if your safc is -40 across the board, ive had a wideband hooked up once and when i was at -23 across the board on 20psi it started going lean in the upper rpms, that was before cams, cams gave quite a bit more air flow, so at -10 it seems to do fine, but i need to get the wideband back up on it
i gotcha man, ive tryed multiple times, i guess ill just mess with it later maybe i can figure it out
