View Single Post
Old 12-21-2006, 01:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #20 (permalink)
Slippi84 Offline
Proven Member
Slippi84's Avatar
Tech Posts: 3,822
Classifieds Rating: 8
Reputation: Slippi84 is pretty helpful and trustworthySlippi84 is pretty helpful and trustworthy
Quote:
Originally Posted by maximumbob View Post
The car should be turned off. Then put the car in any gear. If it doesn't do this something besides the clutch is wrong. The do the whole try to spin the wheel thing. The master cylinder rod is under the dash and connected to your clutch pedal arm with a big c bracket. From what I understand with just about any clutch change you need to adjust the master cylinder rod.
http://vfaq.com/mods/wayback/clutch_adj.html shows a pic from a '90 but the bracket and rod look the same.
No all you have to do is readjust the clutch pedal engagement point.
____________________________
Sean aka Slippi
View this member's Blog
