The car should be turned off. Then put the car in any gear. If it doesn't do this something besides the clutch is wrong. The do the whole try to spin the wheel thing. The master cylinder rod is under the dash and connected to your clutch pedal arm with a big c bracket. From what I understand with just about any clutch change you need to adjust the master cylinder rod.
http://vfaq.com/mods/wayback/clutch_adj.html shows a pic from a '90 but the bracket and rod look the same.
