theycallmedalgo
- 300
- Jan 15, 2006
Sparta/Montclair,
New_Jersey
I figured no one would respond on the other thread so I had to make another one because this is urgent.
There is no gas pedal pressure now, I cut the cruise control cable and then reinstalled everything. It is plugged in as it was, but now when I press the gas it just goes right to the floor and doesn't raise the rpms at all. I tried it with the car on and off.
Everything worked perfectly until I hacked the cruise control cable, does this cable need to be intact to have the gas pedal work? I pulled on the throttle cable and it moves smoothly like it should, the gas pedal just has no effect on it.
I need to drive my car and theres no gas pedal pressure, someone please help
