91TSi FWD
- 617
- 3
- Jan 26, 2003
Edmonton,
So here's my delema. Once the car gets to its operating temperature, whenever I push the clutch in, the engine just drops to 0rpm & dies, and if it doesn't die, it's struggling to keep idle. It all started after I did a lot of work to the car- 2G mas, new IC piping/intercooler, intake pipe, SAFC, 650 injectors, fpr, EVO III 16G, Type RS BOV(recirculated), Blitz Dual SBC, etc. It will only stall once its in operating temp. The stalling started after the mods were done, it ran like new before.
Even when I was dyno'ing my car to tune it, it was stalling on the dyno. Other than that the dyno went well, couldn't find anything wrong with the fuel curve.
All the belts are tight, plugs are brand new, plug wires are fine, I double checked my ECU, no leaky capacitors, all wires for the SAFC hooked up properly, my throttle body is very clean, fuel flow @ idle is fine & no boost leaks. The only parts I can think of that may be bad are the 2G MAS, cam sensor, or my ECU is just pooched. Also, my battery is always low, I leave it sit for a long time between uses with the alarm on & usualy have to charge it before use, and I don't drive enough to get a good charge.
I've tried the obviouse of just playing with the base idle set screw, but does nothing to help the stalling.
If anyone has any ideas or has run into this kind of problem, any help would be appriciated. its a 5-speed TSi FWD.
Thanks for any and all help.
If this should be in the noob forum, feel free to move it.
I need a better picture of the mas to tell you for sure. Does it look like the picture in the vfaq? Are all your honeycombs intact? I also strongly suggest performing a boost/vacuum leak test, recheck your ignition base timing, make sure through the logger that the ISC/TPS are functioning and in proper range.
Yeah, that's how much I drive my Talon. When the batteries died, I lost my software.
