Step 6: Intercooler
This step is also quite vague. you have many choices when it comes to this. you could go FMIC, SMIC, 1g SMIC or 2g SMIC or no intercooler at all. since i have a 2g SMIC ill show you how i mounted mine. mine is actually only being held on by one bolt with a lot of washers lol. first i had to remove the fuse box's bolts and move it around so you can remove the black plastic piece right under it. this is where the inlet is. then i had to butcher up some of the splash gauge to fit the IC outlet. Then you have ot figure out where you want to route your IC pipes, and make the pipes. heres some pics of the pipe when i painted them and my IC mounted.
____________________________
-Chris
