View Single Post
Old 03-15-2005, 07:15 AM   #5 (permalink)
GSGoinFast
DSM N/T Wiseman
Region: Midwest
Classifieds Rating: (0)
Reputation: GSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening to
Quote:
Originally Posted by cine135
Ok, I visited the local speed shop and they recommended either a new rising rate FPR or A piggyback FMU.
I know about the vortech FPR and the Apexi safc.
With the FPR I know I'll be getting fuel pressure levels not limited by factory componentry (other than the injectors, which can stand to blast a little bit more fuel) Though I have a feeling that with the Apexi safc, the signals sents to the ecu will simply cause the ecu to deliver a factory set "rich" condition at the rpms I specify. Is the Apexi unit really effective for a turbo setup?
I'm trying to decide which to go with, this car is not going to be setup for high HP so the boost is staying @ 5psi for the forseeable future.
Which would you recommend?
P.S. If I do go the FPR route what boost to fuel ratio is the 420a fuel system suited for? The speed shop suggested a 12:1, how does that sound?
you need a rising rate fpr. go with the vortech fmu. a s-afc is for fine tuning, not for increasing fuel for boost. your injectors can only open for so long at high rpms. get the 12:1 vortech fmu. you will also need a new fuel pump, get a walbro 255
Offline
