Question before I buy a MAFT
whitetiger777
80
May 4, 2004
Aumsville, Oregon
After installing my Evo III 16G turbo, 650cc injectors and 190 fuel pump, I now find myself in need of some sort of fuel management. I was looking at getting a MAF-T set up, but quickly relised that there are many difforent versions, ie V 2.0, V1.83, V1.3. What are the difforenced between these versions?
Ok, there are not a lot of threds on this sight. The only thing I've found so far is a tuning guid for version 2.0
All you have to do is, become a member. Then do a search. And u will find all the info you need. That's the place that invented the product. So u should find it there. Thanks :thumb:
The 2.0 is the latest version and the only one sold by fullthrottlespeed. Used you could get an older version.
You still might want an AFPR for the tuning it adds. 650's are the limit, you may want to get an EPROM ECU and get a keydiver chip from www.dsmchips.com as youmay find yourself fighting high timing.
