overdoseheroin
- 219
- 4
- Dec 4, 2004
your mom,
Minnesota
ok, i just flowbenched a stock 1g head and heres the results.
INTAKE
.100 lift : 78.44 cfm
.200 lift : 149.94 cfm
.300 lift : 204.33 cfm
.350 lift : 217.56 cfm
.400 lift : 224.91 cfm
EXHAUST
.100 lift : 84.42 cfm
.200 lift : 170.2 cfm
.300 lift : 204.88 cfm
.350 lift : 206.45 cfm
at .300 lift there was 100% intake-to-exhaust flow. my instrustor said his 8 second Fury with a 440 only has 80% intake to exhaust flow. now, after doing this flowbench, i went and did a MILD port job to the intake, all i did was take the lips off the inside of where the valve seat is and the burrs on the outside of the runners. i have a lot more to take out but heres the results from just taking the edges out.
STOCK INTAKE //////////////////////// MILD PORTED INTAKE
.100 lift : 78.44 cfm ////////////// .100 lift : 82.88
.200 lift : 149.94 cfm ///////////// .200 lift : 157.29
.300 lift : 204.33 cfm //////////// .300 lift : 221.97
.350 lift : 217.56 cfm //////////// .350 lift : 235.2
.400 lift : 224.91 cfm /////////// .400 lift : 244.02
it gained 20 more cfm at .400 lift with just smoothing out the edges. im going to finish things up on monday and post the results of the completely ported head. intake and exhaust.
INTAKE
EXHAUST
glad to see another head porter out there! out of curiousity... are you going to unshroud the valves a little bit? are you planning on doing any combustion chamber work, or are you only working the bowls and runners?
