mwreed
- 84
- May 5, 2003
Phoenix,
Arizona
I just did a run this morning. I know that I am knocking too much, but, my concern is this. I was having high end issues... missing, backfireing and such. I got is fixed by lowering the fuel pressure. Apparently, I had it set at 43psi.
I dropped it back down to 37 and it runs good know. I was getting some knock before and my O2's seemed to be a bit high, so, I thought maybe a little rich knock. I know to not trust the O2, but, it was at .94 pretty consistantly. This run, I was at about .90, which seems right for a '90. I'm running at 15psi boost and holding with 91 octane. My mods are in my profile, aside from the BPR7ES's I just added the other day. My question is what do you think? Add fuel? I'm going to try it today anyway, unless someone says no, but, I wanted to get some input. Here's my log:
100.00% 827.6 hz 0.82V 3156.25rpm 23.00º 0
100.00% 981.2 hz 0.90V 3281.25rpm 19.00º 0
100.00% 1220.2 hz 0.92V 3468.75rpm 15.00º 0
100.00% 1434.1 hz 0.92V 3718.75rpm 16.00º 0
100.00% 1547.3 hz 0.92V 4000.00rpm 14.00º 12
100.00% 1534.7 hz 0.92V 4156.25rpm 11.00º 18
100.00% 1710.8 hz 0.92V 4500.00rpm 11.00º 18
100.00% 1861.8 hz 0.92V 4562.50rpm 11.00º 17
100.00% 1912.1 hz 0.92V 5031.25rpm 13.00º 17
100.00% 1937.3 hz 0.92V 5062.50rpm 13.00º 17
100.00% 1912.1 hz 0.92V 5156.25rpm 15.00º 16
100.00% 1987.6 hz 0.90V 5468.75rpm 16.00º 16
100.00% 2063.1 hz 0.90V 5593.75rpm 16.00º 17
100.00% 2063.1 hz 0.90V 5875.00rpm 17.00º 16
100.00% 2075.6 hz 0.90V 5937.50rpm 17.00º 16
100.00% 2176.3 hz 0.90V 5968.75rpm 18.00º 16
100.00% 2151.1 hz 0.92V 6156.25rpm 17.00º 15
100.00% 2201.4 hz 0.90V 6468.75rpm 17.00º 15
100.00% 2201.4 hz 0.92V 6437.50rpm 16.00º 15
100.00% 2188.9 hz 0.90V 6562.50rpm 15.00º 14
100.00% 2188.9 hz 0.90V 6687.50rpm 15.00º 14
100.00% 2214.0 hz 0.90V 6687.50rpm 15.00º 14
100.00% 2226.6 hz 0.92V 7062.50rpm 13.00º 14
100.00% 2201.4 hz 0.92V 6906.25rpm 14.00º 13
100.00% 2113.4 hz 0.92V 7156.25rpm 13.00º 13
I'm logging MAF too, becuase I am using E-manage and the additonal injector pulse is based on MAF right now, until I change to the pressure sensor.
Thanks,
Mike
I dropped it back down to 37 and it runs good know. I was getting some knock before and my O2's seemed to be a bit high, so, I thought maybe a little rich knock. I know to not trust the O2, but, it was at .94 pretty consistantly. This run, I was at about .90, which seems right for a '90. I'm running at 15psi boost and holding with 91 octane. My mods are in my profile, aside from the BPR7ES's I just added the other day. My question is what do you think? Add fuel? I'm going to try it today anyway, unless someone says no, but, I wanted to get some input. Here's my log:100.00% 827.6 hz 0.82V 3156.25rpm 23.00º 0
Thanks,
Mike
Also, the O2 sensor is brand new. Not that I am relying on it. It just seemed odd. I think I have it figured out though. I added some fuel at about 4k and gradually take some out as it increases airflow and rpm. Seems to be working. If I add too much fuel, the top end doesn't like it. It acts like a misfire. I just have to find the right setting and I'll be good. This one seems to be ok, but, I still get a tiny issue at about 6500 rpm. Just need to tweek it a bit more. Here is my log from this morning.
. I only rev that high for loggin purposes anyway..
