Need a little help setting up my SAFC-II(PLEASE!!)
TSiGoesPsSsSst
977
14
Sep 5, 2003
Swansea, Massachusetts
I was wondering if anyone could give me some base settings,where the car should run half-way decent :| I would greatly appreciate any help at all.
Im running a PTE 50 Trim
No AFPR (I know bad,but it will change soon)
255lph walbro
650cc injectors
Thanks.Youll be helping me out ALOT
Well I have the exact same fuel setup as you only running a GT30 56 trim. Had it wideband tuned at 11:1 at 20psi on 92 octane pump
Low Settings=
1K- 10
2k- 22
3K- 25 rest of the way up
High Settings=
3K -30
4K -30
5K -30
5.6K -28
6K -28
7K -27
7.5K -27
Good luck :thumb:
Yep I would agree. I would put the highs at like -25 at first to be safe and see if you can go any leaner from there.
And for the Low's...only your logger can tell you that :thumb:
OMG guys thanks so much.I think I found out my cars problem now (see my other thread - http://www.dsmtuners.com/forums/showthread.php?t=171817)
My car was only drivable with +40 to 50% on the highs.and about -1% in the lows.Anything closer to zero and it did not want to move at all.It would only would boost about 6 or 7 psi then start to bog and backfire like crazy.The car mustve been running piss rich.
