InFlames
- 445
- 1
- Mar 7, 2002
Long Island,
New York
I have a problem (obviously
) My car has been making a rattling sound for the past two days. At first I thought it was the exhaust pipes. But today, I took it around the block and it started jerking real bad, even with the clutch was fully depressed. Then, as Im driving at about 10mph the rear wheels lock up and the car can not move foward or backward!!! Eventually I got it home, driving in reverse. The only way the car would move is if I rode the clutch in reverse... if I depressed the clutch all the way, the car would stop moving instantly...
So, I jacked up the rear and unbolted the drive shaft, and the rear wheels move very smoothly, with no clunking or binding.
So, does anybody have any suggestions? Could this be the center diff? the transfer case? or something else??? please help!
-thanks
) My car has been making a rattling sound for the past two days. At first I thought it was the exhaust pipes. But today, I took it around the block and it started jerking real bad, even with the clutch was fully depressed. Then, as Im driving at about 10mph the rear wheels lock up and the car can not move foward or backward!!! Eventually I got it home, driving in reverse. The only way the car would move is if I rode the clutch in reverse... if I depressed the clutch all the way, the car would stop moving instantly...So, I jacked up the rear and unbolted the drive shaft, and the rear wheels move very smoothly, with no clunking or binding.
-thanks
jay
