slow99eclipse
- 71
- 1
- Sep 30, 2003
I have a 99 GS 10th anni. N/T. Is it a 6 or 7 bolt engine because I was thinking about getting the stage 3 kit off of slowboyracing?? I will be adding a turbo in a month... just waiting on it to arrive... but do you think this kit would do me any good?? (what is the stroker kit? is it a major upgrade from my 420a?) Right now my car only has 57k on it, so should I wait til it starts to go bad or should I just try to eliminate the problem before it happens??
Kit Includes:
Custom SBR Pro-Billet Aluminum Rods Or Manley Rods (YOUR CHOICE)
Custom SBR racing pistons ( big shot of nitrous welcome, lots of boost etc... They'll Love It! )
Clevite Main Bearings
Clevite Rod Bearings
4G64 crank
SBR Ross Racing 6 Bolt Stroker Piston Compression Ratio - 7.5:1
Manley 6 Bolt OR GRP Aluminum Extreme Rod Length - 5.900"
$1600
-------------OR--------------
should I get.....
Here we offer the most complete basic engine rebuilt kit. We offer .20 over 8.0:1 pistons, rod and main bearings, b/s bearing, freeze plugs, timing belt, b/s belt, and a full gasket set. The gasket set includes a head gasket, metal exhaust manifold gasket, intake manifold gasket, O-rings, semi-circular plug, distributor O ring, valve stem seal, cam seals, thermostat housing gasket, EGR valve gasket, exhaust pipe flange, throttle body, valve cover, water outlet and spark plug tube seals.
Top Line basic engine rebuild kit The kit includes: 8.0:1 4G63 pistons Rod bearings Mains B/S Bearing Freeze plugs 4G63 Timing Belt 4G63 B/S Belt Full Engine Gasket Set Front case cover Oil pump gears Please specify what bearing used in the rebuild kit: Standard, 10 over, 20 over. Also please specify what pistons are used: Standard, 20 over, 40 over.
$499.00 :thumbdown OR
Kit Includes:
4G64 crank
$1600 -------------OR--------------
should I get.....
