Proper installation/position of thermostat
FWD98GST
149
Apr 6, 2003
San Diego, California
Hey guys,
I just replaced my thermostat and I was wondering if there was a proper position where to seat the thermostat... I do have that problem of overheating and doing the little steps to cool down my motor...
Just wondering if there is a specific position of the thermostat to be seated or all I have to do is just to plug it in and you're good to go...
Thanks,
Ion
98GST
so there is a certain way to seat the thermostat? Jiggle valve? I'm not too good with thermostat terminology, but as of now, the thermostat seats in well and is snugged... Let me know wassup with the Jiggle Valve? Thanks
It's a small loose pin going thru a small hole in the thermostat housing to allow a tiny amount of flow for pressure release. If you shaked the thermostat in your hand it would jiggle. Not all have them - don't worry about it if yours doesn't. If it does, it should be up (above the thermostat center) not down (below the center).
Is this the same for a 1g about the jiggle valve facing up?
Yes, if it has one.
