View Single Post
Old 12-15-2004, 05:21 PM   #2 (permalink)
92tsi123
Proven Member
Classifieds Rating: (0)
Reputation: 92tsi123 is an unknown
what do you mean by boot, if it is the rubber around the upper part of the ball joint, then yes the ball joint can be replaced, instead of buying a new control are, parts stors will carry the ball joint sereratly. you will have to get the old ones out. you can rent a ball joint puller or buy one, from a parts store. or use a impact hammer and hammer the old ones out, and use the puller to put the new ones in. if you heat the old ball joint up while in the arm, it will come out easyer.
Offline
[posts] Reply With Quote
Sponsored Links
