Be careful with the FCD. If you are running into problems with feul cut and you have no feul management than gittin a FCD may ruin your engine. Start with feul management, set boost levels at conservative levels. The 16g is a high effeciency turbo that can likely boost hard and blow an engine, heck the 14b's can do serious damage by itself. Save up for some sort of feul management sys, and your buddys FCD wont work on your car, he has the k3 if he owns a 1g, you need the standard according to the HKS website.
