Suparata
DSM Wiseman
- 458
- 14
- Jan 18, 2003
Chicago,
Illinois
First of all there is no need for a higher volume or a higher pressure oil pump on a 4G6x since the stock flows too much at high RPM anyway so take care of the pressure relief valve instead.
Second the squirters do not open until you get to close to 40PSI anyway so what do you guys hope to achieve by eliminating one of the best thing the 6 bolt engines have? Sure as hell you wont get any more pressure at idle and low RPM and trying to get more pressure where is needed at higher RPM argument does not stand since you should have close to 80PSI as soon as you go beyond 2500RPM even with the squirters in place. That is plenty where is needed.
Mitsubishi went through redesigning 3 times the distribution valve in the head and the one with the pressure relief valve was the first they dropped. Reason? There is only so much oil that can flow through a certain size hole. Which brings me to the next problem I have with what people try to do to improve oil pressure. You guys go through all sorts of troubles to improve oil delivery to the engine and then choke the system with external lines that are smaller than should be. While -8AN might be good for fuel delivery or transmission cooler, anything smaller than -10AN in the oil system is a restriction.
It is nice to have as high as possible oil pressure at idle but too much at higher engine loads is not so good for several reasons. Besides the load that the pump itself is subject to, the higher the pressure the hotter the oil will be making one of the most important things the oil does in an engine not as effective as it should be: cooling.
Bottom line, eliminating squirters and other clever things like that done to raise oil pressure is more than a waste of time: it is also a bad decision. Make sure you have the right clearances in the engine, use a good external oil cooler with adequate sized lines, modify the pressure relief valve and sit back and watch your engine being a very happy engine.
should that be okay? I also bought an earls turbo oil filter / restrictor to keep superhigh oil pressure from blowin' that money up.
