Weird Backfire/Fuel Cut Issue...
I am having trouble with my talon. I ran a 13.54 the other night at 96 mph(top end is a little lacking due to lack of tuning). On the way home and ever since, sometimes when I floor it, after boost builds and steadies, I hit what seems to be a fuel cut, then it might do it again a few 1000rpm later or it might not. My afpr is set @ 42 psi because any higher and you can feel the loss of top end badly. I am running 18 psi, 91 octane gas, 550cc inj, 255lph pump, new fuel filter, aeromotive afpr, big t28 killer, etc. Could I need a front mount that badly? more octane? could my maf sensor be leaking thru my new homemade intake pipe(I really doubt it, ive tightened and checked thoroughly)? I changed the plugs, and I can't find any problems. I have turned up/down the afpr to see if it changed anything and it did not. The logger results say im rich, but timing is dropping to +6 degrees and then climbing, so if you guys know what it could be...thanks!
