1fast97gsx
- 4,517
- 17
- Jul 6, 2003
Orland Park,
Illinois
I painted my head since it jsut got cleaned up at the machine shop and I had downtime. I just painted it a silver/aluminum color to make it look new again, however after 2 days the paint still seems to "rub off" when I rub a finger across it. It doesn't really smear or mess up the look of it ... it just leaves a little pain on my finger. I used engine paint from a local pep boys and brushed it on. Is it always going to be doing this or is there any special way to make it "cure" so it won't do this? Is there a special type of paint I should be using instead? If so how would I remove this paint then?
... but it says curing must be done within 8 hours. Obviously I can't start the car since the engine is out of it but will I still be ok or is it just going to flake off? Seems like it should still cure normally right?
