Pizzy
- 59
- Dec 23, 2002
San Jose,
California
Hasn't everyone agreed that the B&M (a)fpr is crap because it can't lower fuel pressure?
shadywang said:ok..heres what i have, and my problem....any help is great
1G talon 6 bolt
stock internals
16G turbo
550 CC injectors
3 inch MAF w. translator V.2.10
AFC
i tried setting the MAFT to zeroed out, and tried to tune with AFC, but it still idles like crap, between 900-1500 rpms fluctuating, sometimes stalling. also, my readings on my AFC for my O2 are really low at idle, .000 to .015. nothin on my A/F gauge unless i give it some throttle. any help would be great. i did search, nothing really with the same problem using the MAFT. thanks
Ron
Omega said:Pizzy, is that the one that just modifies the stock FPR? I wouldn't consider it crap because you can't lower the pressure.
Pizzy said:Yes that's the one I'm talking about...where you have to cut off the top of the stock FPR. Don't get me wrong, it's good for raising fuel pressure, but if it would need to be lowered as is usually the case with an upgraded pump (ie 255) then it doesn't do you much good as far as I understand it.
I'm buying one soon, I just have a good deal on injectors right now, wich i gotta take first, and i also can borrow one so Thanks I will come back with more InfoLandoAWD said:I guess you need a logger.
well at idle i am still at 37psi so there is nothing wrong, i still don't know how it is at wot so ....?Pizzy said:But no, I thought that if you have a 255 pump with a stock FPR, it is completely overrun and your fuel pressure is higher than stock. That's why you would need an AFPR that turns the pressure down, because the stock FPR can only keep stock levels with a weaker pump (190 is the highest you can still use the stock FPR I think).
papifry said:AND WHAT IF YOU HAVE A WALBRO 255 LPH FPR "HIGH PRESSURE VERSION" LIKE ME... I DONT SEEM TO HAVE A FUEL PROBLEM RUNNING 680s. I ASSUMED I WOULDNT NEED AN AFPR BECAUSE THE FUEL PUMP WOULD SUPPLY SUFFICIENT PRESSURE. AM I WRONG??![]()
Omega said:You are not lowering it persay, just able to get it normal.
papifry said:So now the question of the day is.....
Will running a higher than stock fuel pressure hurt anything??
I have an AFC II & I cant set my Ne-Point settings in 500's it only let's me set it in 200's. So if I want to set an rpm of 1500 of to go with 1400rpm or 1600rpm. Anyone else having this problem? How do I get around this? Thanks!
i was checking my mail and seen that I had this subscribed. I got rid of my dsm as well, trying fox body route
