jsicfy
- May 18, 2004
fort collins,
Colorado
Does any one here know a mathmatical formula to convert the cfm flow of somthing into how much HP it will support? Like if it were to flow 600 cfm and support 600 hp.
Note: This feature currently requires accessing the site using the built-in Safari browser.
loreak said:divide cfm by 14.7 and that is lb/min
95GSXRacer said:Edit> If you know the temperature and pressure, you can convert CFM to lbs/min by the way. The formulas are out there on the internet I'm sure.
There was a thread a while back on here about it:95GSXracer said:If you know the temperature and pressure, you can convert CFM to lbs/min by the way. The formulas are out there on the internet I'm sure.
