16g Spoolin TSi
- 126
- Feb 19, 2004
Merrimack,
New Hampshire
After much messing around with my AFC trying different settings and many recommended ones i am still hitting fuel cut, currently my lo thr is -15% 1k-7k and my highs are 0% and my thr settings are 50%-80%.... fuel cut usually comes around 35% throttle... any ideas advice on what i'm doing wrong.
The logger also won't connect to my car, i know my obd2 port works because ive had scanners on and off my car, i was told the byte timing could be not set properly but when i set it to 11 i still get the X on my datalogger...
This tuning is so fustrating
~Johnny
~Johnny
... but anyways thats my plan... so i won't know until possibly monday of next week, but i thought it was boost leak at first but i don't hear one usually in the past they have all been pretty noticeable but i'll tell you what i find after the smoke test... and i think i'm also going to disconnect that BCS harness as well just bc to me it seems with all the vac lines disconnected the ECU thinks thinks this thing should still be regulating something, correct me if i'm wrong but that seems somewhat accurate.
