View Single Post
Old 07-19-2004, 01:29 PM   #10 (permalink)
GSXlaunch
Proven Member
Classifieds Rating: (0)
Reputation: GSXlaunch isn't as helpful as most
Oil pan bolts under oil pump gear...
I just got done with the balance shaft emlimination kit...put the motor back in the car and somehow just came across this http://www.vallotton.com/engineremovalb.asp near the bottom it says that there are two bolts that are shorter than all the rest on the oil pan under the oil pump gear. It says if these arent installed where they came off the longer bolts will tear the timing belt. I went by the balance shaft elim on vfaq and had the chiltons manual handy and neither mentioned anything about this. Is this true? If so, I did not pay attention to the bolt lengths when reinstalling the oil pan. Can someone tell me what length those two bolts are? I will get some new ones to replace the other two. Thanks fellas...
TT
Offline
[posts] Reply With Quote
Sponsored Links
