View Single Post
Old 07-16-2004, 02:34 PM   #1 (permalink)
jd99gst
Proven Member
Classifieds Rating: (0)
Reputation: jd99gst is an unknown
Amplifier install
This installation was done in a 99 GST Spyder. I know for certain there are differences in the trunk part, but to my knowledge, the rest of the article should be completely applicable. I took the pictures a week after I installed it.
I assume you have the following items:
An amplifier.
Amplifier power cables, remote lead cable, coaxial cables.
A screwdriver.
A pair of pliers.
ABSOLUTE FIRST STEP: Disconnect the negative terminal of the battery. You do not want to learn this lesson through experimentation.
Power
Now, you're going to want to insert the power cable through the grommet found by lifting the carpet up in front of the passenger seat. I took two pictures to show where it is, but it's really obvious.
After you fish this through there, you're going to need a hanger (and preferably, a second person) to fish it up to the top of the engine bay. Push the fuse through as far as you can get it, and wrap the hanger wire right underneath it for best results. We'll connect it later, as I don't like having live wires sitting around.
To the right of the grommet you put the power cable through, there will be a slide-type fastener, pull it out. To the right of that, on the side of the car, is a screw connecting the panel. Unscrew that, and pull the panel away. You can now safely pull up the side panel on the bottom of the door, as pictured here. There are only clips holding it in.
Run the wires from the grommet, underneath the carpet along the side of the car, and run it through the hole that is now exposed underneath the floor panel.
There are two clips like this, one on each side. Pull it, then pull the seat up. After disconnecting this, the whole back seat comes out. Put it somewhere clean.
Unscrew this screw. You should now be able to run the power cable through the carpet and underneath the panel you just unscrewed. It will run through a gap in the body where other wires are coming from - this may take some wiggling to get through. I do it this way because it takes the least amount of disassembling of the car.
The backing of the trunk is clipped on. You should be able to get them all off without much problem, and run the power wire to the trunk, as shown.
You'll also want to set up your ground wire now. Pick a nonpainted place on the body (or scape the paint off, like me), and screw it down.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
