fuel pump upgrade, bad gas milege, rich air/fuel ratio
prettyba
Mar 25, 2004
Colonial Heights, Virginia
please help. i have a 1997 eclipse gsx upgraded turbo (16g) and inercooler and air intake and exhaust.
i recently decided after buying the car to put a boost cotroller and fuel pump on it.
i put a 255 walbro fuel pump in and my gas milege has went to hell to say the least. i knew it was going to go dow some but this is really bad. but before i put the factory pump back in i wanted to know if i could fix ths problem beings though i already bought and have the upgraded pump in.
i instaled a air fuel gauge and it says i am running really rich on the fuel so i was thinking would a afc fix my problem or is there a way to turn the pump down by adding more air like turning up the boost.
just for note i have the apexi avcr boost controller and that thing is so confusing i dont know how really work that thing eiher. all i know is i am only running 12 psi and it does not reach full boost until the end of the rpm range. like after 5000 rpm. if anyone out there can help i have read and read stuff in forums and i just need somebody to tell me what the hell to do. i really want to get the car running at least 18 psi.
greeneclipse said:
you might need an fuel pressure regulator.
is that a stock part that is on the car or just a aftermarket . if you could expand on why you think that i need a pressure regulator
