trickedoutdsm
- Jun 27, 2003
ok i was wondering if i had a boost leak or if the bearings in my turbo are gone. when im at wot im only running around 7psi until 5g then it drops to 5psi. also the turbo is pretty loud and it is mostly stock except for a cut air can and k&n filter. also there is a sound coming out of the exhaust like air escaping. i let my friend drive by at wot and it sounds like a B-52 taking off. i have redone all of the intake hoses because they were kindof getting bad and i noticed that there is oil coating the whole intake tract.. is this a bad turbo?. i still havent done a leak test but have done the thing some1 sed about spraying carberator cleaner on all of the joints to see if the revs rise.. and that checked fine. please help
