9) The firewall. Unless you have a system, or something where there is a grommeted hole in your firewall, you will need to drill one like me. i drilled the hole, and ran both the red wire from the box, and a section of the extra red wire through the hole. i made a custom grommet out of a fuel line from an RC plane and some electrical tape. Using the plugs provided, find a combonation to connect the red wire from the box to the unfused end of the arming switch, and connect the fused wire of the arming switch to the extra red wire. clamp and electrical tape.
the hole i drilled is right to the right of the steering colum
